vibration
recently i replaced my flex dampner along with my differential. At the same time i replaced my timing redone and replaced all appropriate belts. I am still getting vibration
when the car is in gear you can hear it a lot when i'am driving it is less noticeable my mechanic suggests replacing my balance shafts (he is not sure that is the problem).
i have also replaced engine mounts about a year ago
any suggestions as to what the vibrations is it is very annoying.
183000 miles
not likely to be the shaft themselves - likely the belt is off position - it is very common to have a shop incorrectly install the belt, and put one shaft 180 degrees out - even though the "marks" line up
