Threads: 16
Hi,
I am experiencing awful engine vibration (as if motor mounts were bad) (not shaking) only at idle. If I operate the power windows when they are already up, idle drops a bit and the vibration worsens. I have a brand new battery. Alternator reads 13.4 volts. No lights dimming or anything. Balance shaft rechecked. Do you think a faulty alternator may be lugging the engine making it vibrate?
I am not sure if the <acronym title='dual mass flywheel'>DMF</acronym> is expiring. Car does not vibrate at all above 1100 rpm all the way to red line. Don't know whether it is the alternator or the <acronym title='dual mass flywheel'>DMF</acronym>. Also headlights vibrate on idle and vibration worsens when aux fans kick in at high speed or when compressor engages vibrations worsens for a couple of seconds before idle stabilizes. Motor mounts were recently replaced and are OK.
Any suggestions?
Luis
'93 968 Rhodamine Red Metallic Euro-Spec Coupe with rare M150 (no oxygen sensor or cat) optional package
Threads: 13
Do al the cilinders work correct? Enough fuel and spark? The engine is 100%? No bad cilinders or so?
Threads: 51
Is the car a Tip or 6 speed?
87 944S
19 Audi A6 3.0T
03 Toyota Tundra
Threads: 16
Luis
Threads: 16
My compressor is brand new and was replaced correctly using the proper procedure.
Luis
Threads: 16
I don't want to spend 1k on a <acronym title='dual mass flywheel'>DMF</acronym> without knowing the exact symptoms. Someone posted that vibrating headlamps and idle vibration that goes away at 1100 RPM's and above indicate an expiring <acronym title='dual mass flywheel'>DMF</acronym>.
Any comments?
Luis
Threads: 16
What about when I operate the power windows for example and the window is already up and the car vibrates pretty bad and idle drops. Is this normal on 968's? Or I may have an alternator issue?
Luis
