Threads: 142
Hi folks,
So the car has been tramlining, rally bad, feels like it is getting worse. One piece of history is last January I had the steering rack replaced, and installed the Koni yellow shocks all the way around. They also did a 4 wheel alignment. Nothing else new since then, no changes, no events. And this tramlining wasn't here before this repair, it happened after.
Anyway, the tramlining is starting to drive me nuts. They repaved, or coated a few of the roads around here, some kind of thin overlay that was put on unevenly. And literally the car keeps jerking side to side; enough! It had a bit of this effect last spring, I figured it was just because of the extra firm ride from the Konis. I dialed the front ones down to the "softest" setting, the rears are supposed to be at "medium" from the install at the shop.
I am starting to wonder about the alignment, it could be my imagination, but the car literal looks like it has a bit of toe-out! Did they do the alignment wrong last Jan? Could the adjustment on the tie rods be loose and now drifting? Is there a way I can do a rough check on the toe at home (using strings / yardsticks or something like that?
Roland
Roland
Threads: 142
Hi Flash,
Thanks I don't have a 4 ft. level, used to, also used to have other tools that can't be found anymore; man the stuff disappears, don't know how, wife, kids, workers. I always put things back but then they aren't there!
Anyway, I do sometimes get tired of "some of" the shops. With time I grow more skeptical that they are doing things correctly; when I pick the car up it is always "all done, pay here!" with little further comment or explanation.
But you gave me an idea, see below for the geometry. If we hold a straight edge on both of the front tires, lower down where they will clear the bodywork, than maybe we can get a good approximation. Two helpers hold the straight edges, perhaps known good, true lumber with no warp or flex, or any other straight things, like a couple of thick pipes, that are known to have no bend. And then if we measure carefully. In the drawing "A" is just some known distance, could be based at the wheel center, or the leading edge of the tire. And then if we measure X and Y, assume X.A.Y.A is a trapezoid, we can calculate the toe angle, gotta look up the calculation again, but I think this could work. What do you think?
Roland
Threads: 142
Finally got the wheels aligned. Appears the main problems were the right front camber, too much toe in on front wheels, and right rear camber. The car handled significantly better on the drive back home, but I have more evaluation to do. I just don't understand this stuff sometimes, a year ago I paid $250 for a 4 wheel alignment and there has only been normal driving since then; no events that would cause alignment to change that I can think of. Mistake was I didn't ask for the report a year ago. This one was $150, with a shop I really trust, have taken some cars there before. The tech worked on it for just short of 3 hours including a few test drives. Equipment is the "Hunter".
Here is the report, any comments would be valued.
Roland
Threads: 142
Thanks for the feedback Flash, I forgot to mention that I asked for a full inspection of all the bushings, ball joints, etc. They stated emphatically that this is standard procedure for all vehicles they align. They didn't report any problem, but then of course they aren't all that experienced with these cars. I am sure some things are worn, I have all the repair records back to '99, and there aren't any that show front suspension rebuild. Oh the shop is in San Marcos, probably under an hour drive for you if you wanted to try them -- depending on timing I'd meet you there and we could go get coffee while they do the work. Or go drool at Fry's down the road.
Roland
Threads: 142
I used "Alignment Plus" on Grand Avenue in San Marcos. (I don't see a problem in public disclosure,) Third or fourth time I've used them and was always pleased. It was $150. I know what you mean about the front end feeling light, mine doesn't have much of that. It was catching in the freeway cracks, and even slightly uneven pavement areas on asphalt as well. Even felt a little dangerous at times, where the wheel was being jerked around. I have only the one drive home experience from yesterday, but it felt much better. They told me I should get new front tires and that would help; they don't look bad to me, a little worn (evenly) with some tread left.
Roland
Threads: 142
A search on the Internet using "
home wheel alignment" revealed some articles.
Even Hot Rod has one that appears to be very thorough:
http://www.hotrod.com/techarticles/chass...index.html
But as I look at the report for the job I got done yesterday, he was tuning in the hundredths of a degree! Would be tough if not impossible with home methods. Also be ready for lots of time, the service manager told me that the 968 was difficult for the technician since each time he got one wheel dialed in, it changed the settings on the other wheel (alignment is a relative measurement), and he had to go back and forth repeatedly to wheels he already had completed.
Besides, I guess you would need a lift or an oil pit (old days, we once had a home with a garage that had an oil pit), the car has to be on its wheels fully settled. Don't know how someone could get at the 968 suspension otherwise.
Roland
Threads: 7
I had my front shocks replaced last year with Koni Sports. I brought Flash's recommended alignment setting (2) and It was great. The front feels a tiny loose compared to previous stock alignment but feels great with the counters. If you find a good shop, stick with them....
