Threads: 20
I don't know if I'm just getting old and feeble but I've really noticed that my steering takes much more effort than our Explorer. That's just plain wrong. It's great at speed but it kinda' sucks around town.
I don't have to wrestle with the steering wheel while turning and there are no unusual sounds, no leaking etc., it just feels heavier than I think it should.
Is mine normal???
Should I be alarmed? [img]style_emoticons/<#EMO_DIR#>/ohmy.gif[/img]
What does yours feel like?
Dan
'95 968 Coupe
James Dean
Threads: 177
not over boosted like a big Chevy truck but certainly light on the highway and a bit more effort at slow speeds. Still easy to turn the wheel with one hand all the time, however. You have enough power steering fluid?
Kim Strong, Nova Scotia
2022 Mustang Mach-E
Threads: 167
Caster Blocks are a known weak spot also worth checking.
Threads: 20
Thanks guys!
To answer the querries, the fluid level is up to snuff, the reservoir was replaced 2 years ago (couldn't get the top off the old one!), it was refilled with whatever Porsche used at the dealership... I will have to somehow figure out how to tell if the caster blocks are OK (???), the tire pressures are good, I'm not completely certain whether the alignment is still within tolerance; I had it aligned at the same time the P/S reservoir was changed, I think the pump is OK... it's not making any noises at all, I also had the control arm (leading and trailing) bushings replaced with the p/s reservoir.
Might be time to just go on ahead and replace all of the suspension bushings. I reckon if I'm gonna' go that far, I might as well upgrade to M030/coilovers/braces/charlie arms/adjustable caster blocks...... whoooaaa...hold on.... did you feel that??? It felt like I was on some sort of slippery slope there for a second!!! [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
I've got some checking to do this weekend for sure. Thanks all for the help!
Now to find that long island ice tea recipe...
Dan
'95 968 Coupe
James Dean
Threads: 20
Oops, thanks Flash, what I meant was "camber plates" rather than castor blocks.
I haven't driven anyone else's 968 so I really don't have anything to judge it by. I'm only going on my own personal observation and comparisons. I do appreciate the feedback though.
Maybe a suspension rebuild/upgrade is in the works for this winter. So for a guy who tracks the car a few times a year should I go with stock or improved (Delrin) bushings for a rebuild??? Are there any advantages or detriments with improved bushings???
What about strut mounts? Should I go with stock or "monoball" type replacements???
Thanks again for the helpful input!!!
Dan
'95 968 Coupe
James Dean
