10-19-2015, 06:11 PM
I want to replace the CR-1 Radio in my car with an aftermarket navigation unit, and have a couple of questions for anyone that have done this type of replacement:
1) The radio itself is a standard single DIN sized unit, and there is a storage rack below for cassette tapes (how hip is that???). I am wondering if the combined space for both of these units is a standard dual DIN size which will fit an aftermarket Nav system?
2) If I move forward with the replacement, I hope to do as little modification as possible that is irreversible, including cutting into the wiring harness. If possible, I would like to create an "adapter" harness that converts from the standard Becker connector to the connector for my preferred head unit (probably a Kenwood). I know that the aftermarket head unit will come with a connector/harness in pigtail form. I am hoping to buy the mating connector that will plug directly into the existing connector on the harness, and use this to make a "plug and play" adapter harness. Has anyone tried to do this, and if so, where did you get the connector?
3) Also if I go this route, I need to consider where to place some of the accessories for the Nav, including the GPS antenna and the Ipod connector. In the case of the GPS antenna, I know it can go under the dash, as long as it is not covered in metal. Any guidance on places you have seen this located would be helpful? I am thinking of routing the iPod connector into the storage in the arm rest, any experience doing this, either good or bad?
