Threads: 45
Hi All
trying to help a friend here..
he has a TIP and the engine starts on the button, select reverse and its fine, select drive and the engine cuts instantly..
anybody got any ideas as to the cause..
Threads: 45
I will get him to check the fluid
Wondered if might be the micro switches on the gear selector
Threads: 45
the tip warning light does not come on, you could drive it 20 miles backwards and it would be fine, the moment you select a forward gear the engine cuts does not even give the torque converter time to load up.
its just like turning the ignition off....
Threads: 45
I have a suspicion its something to do with the micro switches on the gear selector,
as in you cant start in gear or get the key out
