Hi Folks,
Just fixed this today (yuk, another pain). Went to home depot, Autozone, Pep Boys, and Kragen. <img src="/forum/images/smilies/968/mad.gif" class="smilie" alt="" />
The computer in the 3 auto parts stores show the replacement is bulb number 7506. This is incorrect! A very large bulb. Same with the Sylvania catalog, shows the wrong bulb number. Home Depot did not have any bulbs that matched the size / configuration.
I matched the size to what was on the rack and found the #2721 is the correct bulb. There is also a #2723 of the exact same size but is only 2.3 watts. The correct one 2721 is 9.8 watts. (that is I hope the wattage is correct, I was going by the brightness of the couple of old bulbs that had a bit of life left in them when I tested the unit). Besides, a wattage of 2.3 (the 2723) is really low, they must be for interior usage on some car.
Autozone had 2721 from "Lighting Technologies" and Pep Boys had 2721 from Sylvania. I mixed the 2 brands and there is no noticeable difference (because one shop had only 2 packages).
Each package was $2.99 and contains 2 bulbs, so for a little over $12 I replaced them all. Make sure to replace them all, the 2-3 that were still working when I disassembled the unit went out just from handling it, so they were likely ancient.
Cleaned the contacts with good old Radio Shack contact cleaner, and used a small artist's brush to wiggle a few hairs down into the socket. Seemed to work.
I failed the "brake and light test" a couple of days ago because about 3 of the bulbs were out. Yeah, it stinks, to put the car back on the road I have to get a brake and light test from a certified shop. <img src="/forum/images/smilies/968/huh.gif" class="smilie" alt="" /> $67 for about 10 minutes of work!
Roland
