[quote name='hot968' post='43432' date='Nov 10 2007, 07:49 PM']Has any one had a problem with the sunvisor druping? The previous owner had his garage opener attached to the visor and now it won't go up tight against the roof. I dont know if I need to replace a spring tension thing or need to replace the entire visor? Any help or any one having the same problem greatly appreciated.[/quote]
I have a 93 coupe and had the same problem. I bought a used set from another 968 forum member and replace them. The plastic triangle that holds the metal knuckle split on the old ones.
Good luck
