07-20-2008, 12:34 AM
Folks,
Here is what I decide to do/try to repair the polyurethane side skirts, mainly the long one: attach a sheet of galvanized stock in the recessed area using pop rivets. During the accident the panels came a little loose, and we taped them up during the tow so they are out of the way. Dropped off the car that way, but when I came back a couple days later some idiot apparently had ripped them all the way off.
Here is one of them before:
Here it is with the paint "sanded" off using the speed sander. Also shows the little piece of galvanized sheet metal with both having the holes drilled. I used 1/8" rivets with a 1/4" depth which seemed like good size and has worked well for all of it so far. This was my first time ever using pop rivets, so it took a little experimenting. I bought stainless steel rivets, since I figured this was an exposed area and I wanted it to last - mistake, way overkill. Really hard to cut off using the tool. If you try this, use aluminum rivets. I drilled the polyurethane with a 1/8" drill, and the metal with one size up; the rivet wouldn't go through the metal with 1/8", and this made a nice snug fit on the plastic.
Here is one of the holes done (my photography today wasn't so hot). I used JB Weld in addition to the rivets, you can see some squeezing out the sides. I figured it would help spread the load, and also keep things together; probably way overkill, there isn't much load on these attachment points and I wouldn't do that again. You can see I inserted the rivets from the underside (inside) of the panel, the reason is that one end of a completed pop rivet sticks out more than the other, and I definitely want the flatter end to be flush with the mounting tab on the car. The end that sticks out more in the result won't be visible, it is no taller than the mounting bolt head and both are within the recessed area.
The one above left the metal just a bit thin on the outside edge after I drilled it, gave me some concern so the next one I did with the metal sicking out more, which wont' matter because it is out of sight, and you can trim it how you like after is it mounted and drilled. The mounting hole isn't drilled yet, I do these after the metal is attached to the panel so I can get it exact. On all the metal drilling, don't forget to center punch the hole location before drilling.
Course I haven't mounted the panel yet, I expect it to work well, but will report back if there is any problem. I think these are definitely worth repairing, if I remember correctly they are around $500 each for the long one. I also bought some "flexible bumper repair" epoxy of some type from the local body shop supplier. There is a small crack in one of the panels, and he said that would work very well and sands the same as the polyurethane itself after it is dry. As usual I am interested in feedback if people have other ideas or improvements to this approach.
Bonus question: What is in this picture?
As I was trimming a small slice of steel using some shears, it flew off and lodged into the plywood behind my work area.. <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" /> Oh... and I thought jack stands were starting to scare me too much! Didn't know this one would be dangerous.
Roland
Roland
