06-28-2007, 01:06 PM
OK Folks....here's a weird one...Let's see if the great minds here can help me, because, well, I'm stumped:
Car runs perfectly normal in daily driving. I can romp on it and it NEVER goes over mid mark or just below. Now, when I run the a/c the car, after a short time will run hot (3/4 mark). As I drive the temp goes UP, but as I slow down, the temp comes back DOWN. <img src="/forum/images/smilies/968/unsure.gif" class="smilie" alt="" /> Stop and go driving the car with a/c on will run at normal temp, mi-mark. If I drive the car with the a/c on at freeway speeds or above 45mph, the temp goes UP, but will come back DOWN when I slow down and/or stop.
Water pump, t-stat and fan switch, and coolant were all replace a year ago when I resealed the front of the motor. Granted the ambient temps are about 105F+.....
I have verified that BOTH fans are on, and seem to be turning at high speed, and they will "after run" when I stop/turn off the car.
The car is completely stock other than the 85C fan switch and t-stat. The front lower bumper cover is gone (has been since we bought the car), but the engine cover/tray is intact.
I'm not sure what other pertinant info I could give you to help me diagnose this issue. I have the manual but no info on fan speed or amp draw....so I am assuming the are functioning correctly.
Any help is GREATLY appreciated! TIA!
