Radiator fans on regardless of temp
Seeking troubleshooting advice: my radiator fans are running full speed soon as I turn the ignition key.
I was previously having trouble with them running ALL the time so replaced the fan relay and cleaned the contacts at the resistors on the fire wall, which resolved *that* problem. I bought new resistors but did not install.
What's next? Is there a sensor in the radiator that might have gone bad? Temp gauge reads normally.
Thanks!
1986 Honda VF1000 FII
2016 Volvo XC90 D5 R-Design
Unplug the switch and see if they go off. I have a couple old ones I can send you if you want to try one before you replace yours.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Waylander/MCL968 - many thanks for the pointers. Given the cost I think I'll go new, MCL - but thanks for the offer!
Last Post by chuaed
05-25-2015, 08:33 PM
06-04-2014, 11:48 PM
04-09-2012, 08:34 PM
09-05-2010, 11:54 AM
Last Post by unknown4u
03-17-2010, 04:56 AM
