02-11-2008, 03:44 AM
I went out for a drive in my (new to me) 968 today and when I was starting out it barely started. It would crank just fine but wasn't getting good combustion. It did stumble to life after some prolonged cranking. I was just going across town to the grocery store so I figured that I'd chance it not starting at all the next time. Leaving the store it started up just fine.
So when I got home I figured the first thing to check would be to check the condition of the spark plugs since I was figuring they could stand to be replaced regardless. The spark plugs are definitely ready to be replaced but more disturbing was that the plugs from the #2 and #3 cylinders (the middle two) were covered in oil. Which probably explains why she was so hard to start when cold.
I did some searching here and see that it could be worn spark plug seals (http://www.paragon-products.com/product_...443.08.htm). Does this sound like a likely culprit? Or does it sound like there is something more serious going on?
I've done a lot of wrenching on my Discovery, but not on my 968 (yet). Is replacing the spark plug seals a big job? If not what needs to be done to replace them?
Thanks,
Tim
Thanks,
Tim
