Threads: 77
I'm in the process of rebuilding my friends 911 motor and got to the point of installing the sprak plugs and for some reason I actually glanced at the rebuilding books section on installing spark plugs, probably for the gap setting, and I found this.
"Porsche doesn't recommend the use of anti-seize compund, as detailed in Porsche Techinal Bulletin 9102, Group 2, identifier 2870. The bulletin applies retroactively to all Porsche models and the theory is that the anti-seize tends to act as an electrical insulator between the plug and the cylinder head".
This goes against everything I have always done. Does everyone else not use anti-seize on there spark plugs or?
Threads: 77
That's what I was thinking, but it sounds like Porsche doesn't recommend any anti-seieze. Guess I'll have to try and find that tech bulletin for the actual text of it.
Threads: 77
Thought it was odd to, not sure when the tech bulletin came out, will have to find some way to pull that up.
