spacers and wheels
I am looking at a set of snow tires and wheels
front 225-50R16 on 7x40 16" wheels
rear 205-55R16 on 6x50 16"wheels
I have same tire sizes but wheels presently are
front 7x55
rear 8x52
Will they fit?
spacers?
I do not really understand what spacers do. I think they move the tire further out to the end of wheel well to clear shocks,brakes etc.
How do you figure out spacer size, is it just if you have a 52mm and you are putting on a 40mm you get a 12mm spacer?
Spacer goes between wheel lug plate and wheel?
Looks like you have your description backwards on the set you're considering (front vs. back). They should fit fine. Spacers help clearance issues, offset fitment issues, and can provide a wider track. You subract the spacer width from the offset of the wheel to derive total offset. Lower the number, the further towards the fender, higher the number, the closer to the shock/strut. Good luck.
Rustech
Try Greimann's calculator to check for clearance issues.
Greimann's Wheel Calculator
If this is what you're looking at however, there should be no problems. The wheels and tires are so narrow, you have a LOT of room.
front 205-55R16 on 6x50 16"wheels
rear 225-50R16 on 7x40 16" wheels
Rustech
Last Post by 94SilverCab
01-12-2021, 10:23 AM
Last Post by MCL968
03-01-2017, 11:35 PM
Last Post by Carl968
10-16-2016, 06:40 PM
Last Post by JWahlsten
06-01-2015, 10:35 AM
07-30-2014, 04:04 PM
