Threads: 49
Check another car with the voltmeter before you start replacing parts. The symptoms don't add up for me.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 49
Interesting about the Jeep.
First off, yours would not be the first (or even the 10th) new part that I have seen fail, so don't assume the starter is OK just because it's new.
Second, I would like to see what happens if you jump it with a good battery when it's cold and most likely to crank slowly. That might give you a better idea what the problem is.
Finally, I wonder about the impact a frayed trigger wire would have on your issue, If the wire is unable to send a full power signal from the ignition switch to the solenoid, it could impact the electromagnetic switch that is the solenoid, and not give it enough juice to fully engage. This would be easy to test by jumping the solenoid when the engine is cold to see if it cranks over fast or slow. It's a longshot, but in theory it could be affecting the clamping force of the solenoid.
Just some random thoughts in case the alternator is not the culprit.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 49
A simple check would be to locate the connector on the firewall that powers the solenoid when you start the car (and the alternator when the car is running), and run a jumper from the connector to the solenoid to see if the original wire is toast. As I said, I replaced both those wires with heavier gauge ones and I ran them in separate looms from the heavy power cable that drives the starter. As I understand it, if that trigger wire for the solenoid shorts out against the battery cable, the starter engages and if you left it in gear, the car drives off without you.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
Threads: 49
Yes on all accounts, CCA is what counts, and you probably do have a shorted cell.
Did the ringing sound in the alternator disappear? I suspect that the gremlin that was making the noise in your muffler simply relocated to the alternator when he (all shop gremlins are male, by the way) heard you were changing the exhaust system.
1992 968 Cabriolet
Volvo S60 Turbo AWD
Lexus RX 300 AWD
