i would think the same thing, expect for how much slop there is at the rear - the side loading shims should provide enough "friction" that a rattle cannot occur - it's supposed to be very tight side to side
also, the rubber grommets, when properly installed prevent any rattle - if they are allowed to get out of position though, a rattle can occur - it's kind of tricky, due to the clip, but if you take your time, it works
i suppose it's still possible that a rattle could be generated there, but i think we found out what was going on with the 2 cars that showed it on the first version - an accumulation of tolerance caused minor contact of the long shift rod with the trans tunnel - it did not create any problems shifting, but made some noise
we made a change in the second batch to correct that
i suppose i could go ahead and powder coat the pin from the groove down, which would take up that "gap" - i would then have to include instructions to grease it, so as to prevent the wearing out of the coating - i'll think about it
www.968forums.com
