self oil changing car
to be clear, it is not the line that failed - it was the inferior connector in combination with the hose used - the oem hoses are "fine" as is (assuming they aren't beyond their life expectancy) - however, mixing and matching does not work - i have now replaced the tiny barbs of the stock connector with the more substantial barbs that are used today, making for a much improved line
as to pressure, the indicator only goes to 5 - the pressure can go higher - i regularly see considerably more than that when cold
the workshop manual says the indicator goes from 0 to 5 bar (printed 0...5 bar) and pressure can go from 0.6 to 8 bar(printed 0.6...8bar) - note the 3 dots between each figure, and the absence of the zero point preceding the 8 - a common misinterpretation is that the minimum is 0.6 to 0.8 - that is not what it says - the pressure can go to 8 bar, which is 116lbs - i've never seen it go that high though
arrrrgh - no o-rings today - will have to shoot for tomorrow
Mixing components is definitely not a wise idea - there's no guarantee of a satisfactory swage.
That's really high pressure for any automotive engine. High pressure is not always a good thing...
lol - that's right out of the workshop manual, so i think you'll have to take that one up with porsche
<!--quoteo(post=75202:date=Jul 9 2009, 12:28 AM:name=flash)-->QUOTE (flash @ Jul 9 2009, 12:28 AM) <{POST_SNAPBACK}><!--quotec-->the workshop manual says the indicator goes from 0 to 5 bar (printed 0...5 bar) and pressure can go from 0.6 to 8 bar(printed 0.6...8bar)<!--QuoteEnd--><!--QuoteEEnd-->
Yes, I've seen that in the manual as well. This implies that as long as the pressure is about 0.6 bar, you're OK. On the hottest of days (I live in central Texas, remember), with the engine fully warmed up, mine reads about 1.5, maybe 1.6, at idle. Well above the lower limit, but below what I've heard others quote. Should I be worried?
it's a little low, but not horrible - i wouldn't worry, given the miles on the engine
update on mine -
i drained the last half quart out and checked it out - no flecks or specs - got the o-rings in - installed everything, took a breath and got ready
just fired her up - all is well - no damage i can see - rattled for about 3 seconds while the lifters pumped up then quieted down and went right up to normal pressure
now i'll just finish cleaning up the mess, button her up and take her for a plow this weekend
as soon as i get back i'm sacrificing a chicken or something
Glad to hear things seem to be OK. Always nice to dodge a bullet.
gotta say they built things pretty tough - this is twice i've done this now
<!--quoteo-->QUOTE <!--quotec-->however, mixing and matching does not work<!--QuoteEnd--><!--QuoteEEnd-->
I was merely making a general statement and validating what you said - I'm not pointing fingers at any one assembly or manufacturer... [img]style_emoticons/<#EMO_DIR#>/rolleyes.gif[/img]
no worries - i didn't think you were
<!--quoteo(post=75319:date=Jul 10 2009, 05:09 PM:name=flash)-->QUOTE (flash @ Jul 10 2009, 05:09 PM) <{POST_SNAPBACK}><!--quotec-->just fired her up - all is well - no damage i can see - rattled for about 3 seconds while the lifters pumped up then quieted down and went right up to normal pressure
as soon as i get back i'm sacrificing a chicken or something<!--QuoteEnd--><!--QuoteEEnd-->
WOOO- HOOO ! [img]style_emoticons/<#EMO_DIR#>/smile.gif[/img]
the chicken sacrifice for this is definitely in order, but given the broken balance belt with no collateral damage as well, you best sacrifice a cow or something bigger also.. and I hope you're test driving the car straight to the closest convenience store to buy some lottery tickets
<!--quoteo(post=75319:date=Jul 10 2009, 05:09 PM:name=flash)-->QUOTE (flash @ Jul 10 2009, 05:09 PM) <{POST_SNAPBACK}><!--quotec-->as soon as i get back i'm sacrificing a chicken or something<!--QuoteEnd--><!--QuoteEEnd-->
If it were me I'd also be sacrificing a nice bottle of wine to go along with the chicken.
Chris Vais
2008 Audi A5 Brilliant Black
lol - did the chicken and 3 bottles last night, just to be sure
11-21-2018, 12:46 PM
Last Post by Mitch
05-22-2014, 05:05 PM
Last Post by hot968
05-03-2014, 08:30 PM
