Threads: 19
Seems odd that it will idle at 850 for 30 sec. and then settle in on a higher rpm.
A lot of ECUs increase the idle speed if the A/C is on, or if the engine is cold, decreasing as it warms up, etc. I'm not familiar enough with the 968 yet to know if or when the ECU might increase the rpms and what sensors it uses in its decision making. But, could it be a faulty coolant temp sensor, intake air sensor, or?
'92 Midnight Blue 968 Coupe
Threads: 3
I would not be surprised to find a lot of grit in the ICV or gunk from blowby, etc. They are not hard to clean, and you can use a 9v battery to activate them out of the car. There are also lots of replacement options, BMW Saab, Volvo, etc. I recommend getting a replacement and if it is used, clean it very very well and then swap them out. I think the common Bosch 0 280 140 505 part will swap. One of my cars had an old E30 BMW ISV on it which worked fine despite not even having the 90 degree head.
Cheers,
-Joel.
Joel Frahm
1987 928S4 Diamondblau/Blue
Threads: 77
The whoosh noise is normal, they all seem to do it, some are just louder then others.
