RSBarn Header and Chip installed
[quote name='flash' post='35715' date='May 21 2007, 09:15 AM']any chance you did a leakdown test along the way? while it is very common to try to make a direct connection to an item when changes are being made, it may not be actually connected
i would start with the basics - verify compression at over 180, verify leakdown at below 10%, verify function of variocam - verify function of O2 sensor (new or not) - then check mixture - it sounds like you are running very rich
have the injectors been checked or serviced? do you smell fuel anywhere at any time?[/quote]
I checked compression: it was fine. My mechanic said that obviated the need for a leakdown test. Vacuum has been good. I will keep investigating, with thanks for these tips.
these kinds of problems make me crazy - i feel your pain
good compression does not obviate the need for a leakdown, but it does lessen the liklihood of a big problem (assuming it was over 180, and vacuum at 18 or so at idle, and rock solid)
i would be looking to find the cause of rich running, and not one to assume anything, i would check everything, if only to eliminate it as a possiblity
It seems like a Run-Rite treatment (2nd treatment in a year) applied a couple of weeks ago has solved the black soot problem. Not anything I would have expected!
that stuff is amazing
Last Post by dlearl476
01-27-2025, 07:03 PM
12-06-2015, 07:19 PM
Last Post by White968
10-06-2011, 02:43 AM
02-25-2011, 07:01 PM
02-10-2009, 03:14 PM
