Thanks again to everybody for all the advice. I hope it will prove helpful to anybody needing to replace their mounts in the near future, which probably includes quite a few people, given the age of our cars. Here's how I would summarize the situation:
- No question, go with OEM mounts, not aftermarket. Paragon has them for $103 ea.
- The power steering fluid line sounds like it's best left alone. There's no sign of a leak on mine.
- Ditto for the steering rack. Mine is bone dry on the outside.
- The oil pan gasket is borderline, as mine doesn't seem to have any drips, but given that my pan is fairly damp, I think I'll go ahead and replace the gasket, following all the excellent advice given by several people on this and the other board.
- I'll check the oil pickup tube(s?) for cracks. Not sure if I could see a hairline crack, but I'll take a close look. I'll look in the manual, of course, but if anyone has any good pictures of the oil pickup tube or tubes, I would really appreciate it if you could post them.
- Several of you mentioned the rod bearings. According to the records provided by the PO, my car got an oil change about every 4000 miles. The engine has 89,000 miles, and here are the oil pressure gauge readings, taken on an unseasonably warm day here in Austin (mid 70's, 76 deg on the interior temp gauge), fully warmed up after about 30 minutes of running:
rpm Gauge Reading
idle ~2.2
1200 3.0
2000 ~4.1
3000 ~4.2
6000 ~4.8 (just under the last bar)
The car, especially since the airbox mod, and with the RacerX chip, runs VERY strong. So, my feeling is that the reward associated with replacing the rod bearings at this time probably doesn't outweigh the risk.
- Orphanowner, great input on the cap seal on the rear of the lower balance shaft housing. What exactly is the "gorilla snot" treatment? The seal on the front of the lower balance shaft housing definitely has a small leak, so I'd like to know if this could help here.
- As for the controversial 3-piece crossmember, sorry, Flash, but given that removal of the oil pan is such a rare occurrence under normal circumstances, especially once I get the new gasket in, I just don't can't justify it. My car also has new castor blocks, sway bar & bushings, shocks, etc., and I only put 2-3K miles on it a year, so the front end is unlikely to need any work in the near future. Anybody else out their who has put in the Lindsey Racing unit, and would be willing to join Flash in recommending it? Looks very cool, but I think I'm going to pass.
