Threads: 69
I'm not sure these have ever been cleaned! 20 years of crud.
For those that are feeling adventurous, here's the basics.....
Materials used:
Adam's All Purpose Cleaner (APC) at 100% full strength
Brake Clean
Double sided kitchen scrubbie sponge - one side sponge, one side scrubbie
Some regular terry cloth towels
Various shaped brushes
Bucket with hot water
Rubber Gloves
Goggles
Hat
Not much to the actual step by step, but a few tips. Start in the middle and let gravity allow the APC to rinse down. It will make the cleaning of the lower parts even easier. Be sure to do the backside everything too while you're in there. Once all the dirt is gone, you may even discover you still have some 20 year old cosmoline in there. I had some in the wheel barrels so I guess my wheel barrels have never been cleaned and are original to the car! Your choice to take the cosmoline off or leave it there. Since I was going for clean and my car is white, I took it off. I don't drive this car in rain or snow anyway. APC will slowly dissolve the cosmoline but brake clean works much better...problem is, the brake clean may also take the paint with it! Again, not a problem for this particular project, since I had some single stage Grand Prix White mixed up in a rattle can at my local paint shop. Here are the results.
As Started
Wow, what a difference!
Done.
Passenger Side Complete
(This post was last modified: 11-28-2012, 01:13 PM by
Darryl.)
Threads: 167
Darryl,
I was shocked when I was at your detail day last Spring and we used the APC on my wheel wells. The entire time I owned the car I was not aware that the rear wells were body colored, I always thought they were black (seriously).
Adam's APC is 1,000 times better than simple green.
Threads: 17
[quote name='94SilverCab' timestamp='1354121166' post='135387']
Darryl,
I am also 100% convinced that mine are black , need to check again ???
volvo V70D5 Black
Porsche 968 amethyst
Threads: 69
It is Cosmoline and was sprayed all over everything for the shipment across the Atlantic. When it comes to pure concours type stuff, many people think you should leave it there since it was originally that way, but others think it is OK to remove it. I don't concours my car but want to start getting it cleaned up little by little and will show it more in the future.
As for the value of Cosmoline, as stated above, it's purpose was for anti-corrosion and evidently worked VERY well since it's still all over everything 20 years later, but now instead of fresh, clean and yellow, it's hard, crusty and brown. I guess if you drive on chemical treated roads in snow, slush, and slime, maybe leave it on the undercarriage pieces and parts............or just clean more often!
- Darryl
Threads: 22
looks great. I also never realized that they were the body color. You have been referring to the rear wheel wells only so I have to ask the dumb question. Is it the same situation for the fronts as the rear? If so, any photos of a vehicle with all four cleaned.
Thanks,
Carl
1992, Guards Red, Coupe, 6 spd., LSD, Drilled frt. rotors,
Threads: 11
Now you need to get yourself some whitewall tires.
1993 Porsche 968
2002 Ducati 998S "Bayliss"
2002 BMW 325xiT
2005 BMW K1200S
2006 BMW X5
Threads: 69
Carl968....The front wheel wells have black plastic liners. It is body color behind those liners and does show through at a couple of small places. I will be removing the liners, as that makes it easier to get the front bumper cover off so it can go to the paint shop along with the D1R splitter, cleaning the fronts same as rears, cleaning the liners and then reinstalling everything, so yes, I'll post pics of that process as well.
TSBeckman....I've got some whitewall tire paint in house for re-doing letters on some of my muscle car customers, so maybe I'll do the Toyo T1R letters in white...............well, OK, maybe not!
- Darryl
