Threads: 91
Anyone have a photo of what is under the rear seats when you remove them? Is it carpeted?
1994 968 Coupe / 6-Speed / Guards Red over Black Leather / Bilstein Escort Cup Coil Overs / MO30 Sways / Charley Arms / Adjustable Camber Plates / 17" Cup TWO Alloys / B&B Cat Back Exhaust / Airbox Mod / RS Barn Stage 1 Chip / Classic9 Rear Seat Delete / Saftey Devices Roll Cage / D&L Clubsport Door Panels / ProMax Wiper Delete / D9 Brake Ducts / Design 1 Racing Splitter
Threads: 104
"Anyone have a photo of what is under the rear seats when you remove them? Is it carpeted?"
Coupe or Cab?
Here is my cab with the double glove box unit removed.
92 968 cab, 1 of 1 Mint green cab, full leather black intr, PCNA promo car, 9th cab for NA market, 6 spd, 968 coupe and cab registry keeper. PCA 968 register advocate.
Threads: 91
Sounds like maybe they deleted some of the carpet at some point in production? I've seen the very expensive rear seat delete molded piece for sale at D9. Where did you get just the carpet for this mod? Any photos?
Threads: 104
Almost untouched from factory. After pulling out the cubbies I did remove the rear brackets and added a small piece of carpet from the back of the cubbies to cover the area where the brackets were (you can see that). I then poked a hole through the carpet for access to the inboard seat belt nuts in the floor. All the rest of the carpets were there. Minty looks the same but I purchased a black 944 cab rear seat which I plan to install for a cleaner look.
(This post was last modified: 09-16-2010, 06:00 PM by
jeff968.)
Threads: 15
I'd like to ditch my rear seats. Does anyone know if the top surface of the cubby unit from the cabs sits level with the rear deck in a coupe? I'd like to have a nice big flat storage area back there.
Tho I suppose if I add a cab cubby box I'm not really saving any weight, which is my whole reason for removing the rear seats in the first place!
I suppose I'll start by removing my rear wiper first...
-Austin
-Austin
'94 Black/Tan Coupe
Threads: 15
Paul - now that's what I'm talking about! Did you fab that up yourself? Is it bolted in or just sitting there?
-Austin
-Austin
'94 Black/Tan Coupe
Threads: 9
No, that is definitely the shelf offered by Porsche as standard feature in the Club Sport. My car has exactly the same. It is bolted in by using the rear seatbelt mounting points.
'93 black Porsche 968
'93 silver Porsche 968 M030
'93 black Porsche 968 Club Sport
'93 amazon green Porsche 968 Cabriolet Tiptronic
(This post was last modified: 01-26-2011, 05:52 PM by
Porsche968CS.)
Threads: 65
Depending on where you live, there's another advantage to removing the micro-seats (which, thankfully, my cab doesn't have). Around here we have diamond carpool or "commute" lanes that require at least three passengers to use them. The exception is motorcycles and two seaters. Sans the rear seats, I can jump into the diamond lane with only one passenger. With the rear seats, I'd be looking at a minimum $271 fine in most places.
Bill
'93 Horizon Blue Metallic Cab
'58 Triumph TR3A (sold)
'06 Lexus RX400h Hybrid
Lots of guitars
