07-31-2013, 03:36 PM
So I've only been driving the 968 about twice a week recently. I did a fuel filter change about a month ago, which makes a big change in drivablility, power, and smoothness. it was also causing really slow starts because the check valve was failing and letting the fuel in the line go back to the tank.
I went to start it on Sunday and it did not go smoothly...actually, I basically convinced myself I'd done damage and shouldn't make any further attempts. There were awful noises, a lot of shuddering, and strange read outs from the tach. I left the car alone until last night when I removed the plugs, turned the engine by hand, removed the DME Relay, cranked the engine with the key, put everything back together after finding the engine was not destroyed, and took it for a test drive and everything was fine.
What I did find was about 1" of oil in the #2 and #3 spark plug wells. Also, one of the insulators on the spark plug wire was completely disintegrated. My guess is that this had something to do with the crazy starts. Maybe this oil was causing these spark plugs to short to each other and spark at the wrong time, or at least, to not spark properly when they were supposed to.
I have the oil seal kit for the head cover which should fix this leak. I've been meaning to powdercoat the cover and intake, so I'll do this at the same time as well as replace the hall sender ad check the cam chain and pads.
Anyway, I just thought it was an interesting issue, and might come in handy for someone else.
Cheers
Phil
Cheers
Phil
Sold
