Threads: 11
You should re-ring it, and send it off to a machine shop familiar with our alloy. If your cylinders are flawless, shouldnt be a need to mess with it. Id contact Chris White personally.
www.944enhancement.com
Threads: 11
IIRC Goetze makes a compatible ring, Id clarify with Chris or Mike though.
As far as rebuilding old blocks, I have 15k miles on my rebuilt 944s2 block. The cylinders were flawless, and didnt need to be touched though. You can bore on them, but it requires a process most shops dont know how to do. This is why you should leave this stuff to the experts. This isnt something to do in your garage. At the very least find a reputable machine shop in CA, that can do alusil. IIRC it requires a chemical process.
Threads: 11
[quote name='Cloud9...68' timestamp='1303006844' post='108521']
The machinist I went to told me alusil engines like ours are designed to go a million miles. When you think about it, what is alusil, but a ceramic, and ceramics are some of the hardest substances on earth.
Yes, as an alloy with a composition of 17% silicone polymer, would technically be ceramic. Silicon is a really cool metalloid. Not only very hard, but heat, and wear resistant.
Interesting wiki entry:
Alusil as a
hypereutectic aluminium-
silicon alloy (AlSi17Cu4Mg or A390) contains approximately 78% aluminium and 17% silicon.[sup]
[1][/sup][sup]
[2][/sup] This alloy was created in 1927 by Schweizer & Fehrenbach[sup]
[3][/sup] of Baden-Baden Germany and further developed by
Kolbenschmidt.[sup]
[2][/sup]
The Alusil aluminium alloy is commonly used to make linerless aluminium alloy
engine blocks.[sup]
[4][/sup] Alusil, when etched, will expose a very hard silicon precipitate. The silicon surface is porous enough to hold
oil, and is an excellent bearing surface.
BMW switched from
Nikasil-coated cylinder walls to Alusil in 1996 to eliminate the corrosion problems caused through the use of petrol/gasoline containing sulfur.
Threads: 11
Actually copper, and magnesium. AlSi17
Cu4
Mg Which wouldnt be metalloids (semimetals), but alkaline earth metals.
