01-22-2016, 05:15 AM
Hi
I'm new on here so apologies if this has already been discussed previously.
I recently had an engine rebuild, to standard specification by a local marque specialist.
This was while the engine was out of the car following a shunt at the race track (Donnington Park ), so I thought it would be a good idea to get it refreshed while the car was being rebuilt.
After the engine was stripped, I took several photos of the components, including the block and bores, which were in good serviceable condition.
The engine was rebuilt with new bearings, rings, seals / gaskets, water pump, belts / tensioners, timing chain and a good pair of camshafts to replace the worn originals.
There were no changes to the fuel, exhaust, ECU or other related components following the installation in the car. I used a 15/50 semi synthetic oil, which was changed at 500 miles along with the filter.
Unfortunately the engine smoked on startup and used excessive oil from the first time it ran. I discussed this with the engine builder and they told me it was just the rings bedding in and to put some more miles on it.
So 3000 miles later I now have badly scored bores in all 4 cylinders.
Engine builder is reluctant to help using the excuse that it is more than 12 months since I fitted the engine. I am obviously disputing this as I told them of the problem and took the car back to them inside 12 months ( actually less than 6 months ).
I need to have a good understanding of what could have caused the problem, so I know what to say when I talk to them again.
Please could you give me some suggestions of likely causes?
Thanks in advance
Nick
Thanks in advance
Nick
