09-14-2009, 02:08 PM
After fitting the brake cooling hose adapters from Lindsey I have developed a sound from what seems to be the left front wheel. The noise is a best described as whining and it is accompanied by a sligth buzz in the steering wheel. Sharp right turn makes it worse, sharp left makes it go away. It is speed related and has nothing to do with engine rpm.
Since fitting the adapters involved removing the hubs I naturally assumed that I had f**ked up and hence I checked and reset the play in the wheel bearing on the left front wheel as per the manual, thinking that I had set it to tight. It didn't help. When turning the hub with rotor off there is nothing to indicate something is amiss.
Today I took both hubs off again, gave 'em a good cleaning, checked them thoroughly and applied new grease (the expensive kind). I also lifted the rear up to check if I have a problem in the rear that could cause this but everything is turning nice and smooth.
I have yet to test drive the car after my last fix but I somehow doubt that I have fixed the problem. Any ideas of what could be the cause of this?
(This post was last modified: 09-14-2009, 02:10 PM by firefish.)
