Front dash rattle
Hi all, there is a rattling noise from behind the front dash (somewhere above the glove compartment), happens whenever the road gets bumpy. Is there a way to access this area without removing the entire dash? Would I be able to get access by removing the entire glove compartment housing?
Had a garage remove the front dash some months ago to replace the aircon heat exchanger, clearly something wasn't secured properly when re-installing the dash... Hoping for some advice as the noise has been bugging me for months now!
Thank you.
You can remove the glovebox inner part and lid , will give you acces to the parts behind .
The glovebox light and wiring is bit fiddely , remove the light and disconnetc the wire before removing the glovebox , otherwise  you might break it , disconect battery or take the fuse out  , the light allways turns on so it is always live ,
volvo V70D5 Black
Porsche 968 amethyst
Thanks for the advice, i shall give it a try and hopefully resolve it.
08-29-2023, 04:24 PM
Last Post by Roboman
09-29-2021, 05:42 PM
06-18-2017, 04:40 AM
02-28-2017, 01:58 AM
02-24-2014, 12:52 PM
