Race-header
a bit less by the time you get to the wheels, yes.  the other hard part is even getting the upper range numbers on the dyno, because the tip doesn't want to let you go to redline very easily.
Kunz,
I've been on the road a lot.  I didn't realize Pete had another header out there with larger tubing.  I have the original header and stage II chip, so my results are with the original header.  Can't help you with a larger version.  However, like Bob said the laws of fluid dynamics apply and the torque curve would shift a bit to the right and should result in an increase in flow at higher rpms.  Good for the track, not so much for the street.
I'm going to have my car tuned for next season by one of the local guys (Behe) to extract the power it should be producing.  I had the head cleaned up, and it needs retuned to get the fueling and timing to match.  Again, consequences from messing with the port sizes Porsche designed.  I'm hoping I don't need to change the cams...
Joel
Joel Wahlsten
Talk to Pete about his cam package.
Oh, the slippery slope.  I really wasn't chasing more power just maximizing what was available.  The head flows too much at this point for the stock setup is my hypothesis.
Joel Wahlsten
There is no such thing as a slippery slope. It's called jumping off the cliff!
Last Post by Fox944
01-10-2010, 06:36 PM
Last Post by 94SilverCab
05-22-2007, 10:15 PM
Last Post by RS Barn
10-07-2005, 12:09 PM
Last Post by Jason Judd
10-05-2005, 10:04 AM
