Threads: 46
OK - after getting goofed on last year for leaving the rug in my car I figured I had to rip it out, even though it provided needed weight in the right place. At the end of the day if there's a fire I don't want to breath burning foam and rug.
Many folks had warned me that the germans were very liberal with the glue....that is an understatement! Also, many folks have stated that all old german cars smell the same - some truth to that also. The smell is the rug without a doubt. Ripped that nasty crap out and it did have old car stink ingrained into it.
But the glue - that was brutal. Laid on about an 1/8 inch thick throughout. It took at least 12 hours of slave work to grind that crap off. I used wire wheels, plastic wheels you name it. Finally found that a grinder brush made of thick wire cables would do the job. It would heat up the glue so that it formed into blobs and get flung around in the car. Then I'd pick them up, vacuum repeatedly and keep grinding. I used a heat gun and a scraper. I bought a pnuematic scraper - none were as good as the grinder brush which is not unlike the Snap On Crud Remover tool that costs $490. The grinder brush was $5. Attaches to a high speed grinder and is way better than a wire wheel on a drill.
Then to get the last glue film off the car. Kerosene does the job great but the smell will kill many brain cells. Mineral spirits were best and took the crap off.
I got most of it and gave up and painted over the last 4 hours of crap removal. It looks damn good but not perfect. Has to be the worst job I've ever done. The closest I can recall was chiseling glue off a floor to get it ready for tiling. Actually - this was worse.
Another tough job - repositioning the seat lower and moving my head further from the cage. That took a ton of time also but thankfully worked out great and the car is safter for it.
Now I just need to add another 50 lbs of ballast to the 100 lbs in the footwell that's already there
Car is ready for New Hampshire Pro IT and the Granite State National STU race.
Benspeeder
BigSpeed Racing
1992 ITR Porsche 968
1998 Boxster
2003 F350 V10 XLT Super Duty - hauler
1995 Georgie Boy Cruise Air - 37 ft Coach race car hauler
Threads: 167
I'm glad you took the job on yourself, not sure how many more carpet removals Max has in him before he becomes a jabbering idiot [img]style_emoticons/<#EMO_DIR#>/laugh.gif[/img]
Look forward to seeing you race at NJMP or Poconos this year. It would be great to have a 968 track day with you, Crespo, Pete, etc.
Threads: 30
I feel your pain.... terrible stuff... Neither I nor Max will ever do it again! I'll save for months to pay someone else to do it before I tackle it ever!
But as a well known cage guy said: Hold a torch on one hand and a kerosene or acetone wet rag on the other and it can be done in 1/2 the time... heat, swipe, and repeat.... as long as one does not blow up or die of bad inhalations.....
Glad to hear you got it done... I am sure car is looking great!
#75 RS Barn-Hoosier-AJ Hartman Racing Porsche 968
2012 PCA GT5S NORTH ATLANTIC CHAMPION
2011 NASA PRO RACING (NE) GTS-2 CHAMPION
Track Records: Pocono Long Single Infield CCW | Pocono Double Infield | NJMP Thunderbolt w & w/o Chicane | Lime Rock Park
Threads: 46
I think my IQ was reduced by the fumes! Don't think I'll ever do it again either.
Cheers guys
Benspeeder
BigSpeed Racing
1998 Boxster
Threads: 46
I wish I had a gardener who could do that job.
333PQ333 - heard about the dry ice but a fellow who just did his S2 said the glue had fiberous material and the glue wouldn't crack. He'd used it on Japanese cars that he'd built and it workded fine. Porsche glue is a bear I guess. The same guy mentioned that he used Citrus Orange - slathered it all over the glue and let it sit overnight and then used a plastic scraper to remove it - said it came right off.
Of course I hear about this method AFTER I melted my brain cells breathing mineral oil and kerosene fumes
Benspeeder
BigSpeed Racing
1998 Boxster
