04-09-2011, 08:46 PM
As many of you know through my numerous posts on the subject, I've decided to keep my car and convert it into a mostly-dedicated track car. My immediate goal is to significantly increase its "fun factor" at the track by completely upgrading the suspension (spherical/solid bushings everywhere, much stiffer springs and dramatically upgraded dampers, torsion bar delete, more track-oriented tires and wheels, etc.), taking as much weight as I can out of it, and rebuilding the engine, since I need to upgrade the connecting rods anyway.
But, while my immediate goal is track day fun and having a car that I won't "outgrow" as I make my way through the classes at the local driving academy (Driveway Austin), I'm also keeping one eye on the PCA club racing rulebook, with the thought that I might partake in competitive racing with the car one day, and this is causing me quite a bit of angst.
Here's my major dilemma: As long as I have the engine out and apart, it seems foolish to not take as much rotating mass out of it as I can through the use of lighter pistons, and I would like to lighten, cross-drill, and knife-edge the crank, since I'm only going to have it out once. But looking at the PCA rule book, lightening of the engine internals is strictly forbidden, not only in the stock class, but also, for all intents and purposes, in the spec classes. Plus, I'd like to use as light a flywheel as I can, but the stock class only allows the 18-lb flywheel (although the wording here is ambiguous - it reads, "Suggested substitutions are: ... 968 may use 944S2 or 968 Turbo S flywheel" It's strange to see a word like "suggested" in a rulebook...). So the 12-lb flywheel seems to be out as well. At least headers seem to be allowed. My point is that there isn't a whole lot that can be done to increase the power of these engines, so I want to do everything possible to improve the way the car pulls itself out of corners (that fun factor thing again).
Also, I'd like to do things like relocate the battery to the back, and while this isn't explicitly forbidden, the rules do state something to the effect of, "Just because something isn't explicitly forbidden, don't expect that you can do it," so I'm assuming this is a no-no as well. A lightweight hood (if I could find one) would also be great, but again, this would disqualify me from the stock class.
And then there's the matter of wheels. I'd like to go with 18 x 9's in front with 255/35 tires, and 18 x 10's in the back with 285/30's, but the rules for the stock class only allow up to 8.5" in front. This may sound like a trivial difference, but wheels are very expensive, and I like the idea of minimizing the difference in wheel/tire width between the front and back, since the car has a pretty much 50/50 weight distribution, and staggered wheels/tires on a car like this seems just plain silly.
So, do I say "the heck with the rules, let me have as much fun with the car as I can get away with," with the possibility of major regret down the road? If I'm upfront with the power-that-be (I'm a ridiculously honest person, plus I have no desire to prevail in a particular class by giving my car an undetectable advantage, however slight), and suggest added a little ballast weight to offset the internal lightening, do you think they'd let me run in the stock class? It seems foolish to start ones fledgling amateur racing career in one of the higher classes, right? Or should I forget all about this rotating mass lightening stuff altogether, and keep all other mods I'm planning within the rules for the stock class?
Sorry about the long post, but these are major decisions, and I'm literally losing sleep over them. Thanks.
