Its been a long time coming, but I am almost at the end of my project (this one anyway). I have powder coated my calipers myself at home with an oven I picked up for $20 <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> . I have installed the B&G progressive lowering springs and have rebuilt my old Sachs struts with the Koni inserts from Paragon. If anyone else is thinking of rebuilding their own struts, I say "Go for it!" It is not that difficult and I found a way to measure the length (where to cut) that makes it a cinch. There are three holes in the lower spring perch on the strut, I measured a length of wire to the correct size and inserted it thru the holes and marked the end of the wire. After all 3 marks were made I connected the dots with masking tape for a line to follow while the Sawsall did its magic. No Problemo. Clean 'em paint 'em and insert a long(er) metric bolt in the bottom to snug'em up. Once bottomed out, replace with the nice looking allen cap bolt provided in the kit. I should mention that my bumpstops were in need of replacement. I should have done that before I installed it the first time! <img src="/forum/images/smilies/968/unsure.gif" class="smilie" alt="" /> DOH!
Brake calipers were cleaned with Simple Green Automotive formula. They were then Sandblasted in a cabinet purchase from Harbor Freight for $85. (don't tell the wifee) The powder I used I bought from Ebay (Pendry brand) cooked two colors at 400* for 25 minutes each. The calipers were not disassembled prior to coating just masked off the seals and put bolts in all but one of the holes for the brake lines. I rebuilt the calipers with a kit from Paragon that included new seals and dust covers ~120 I think...dunno, don't quote me on that.
The seals after cooking were strong (streched well and no signs of heat trauma or cracking) I replaced them anyway. It was impossible to tell them apart from the new ones except the old ones (seals) were wet with brake fluid still left in after I drained them overnight. Rebuilding them was not too difficult, about 20 minutes per caliper. Stainless steel brake lines were added too (Thanks again Flash)
At the recommendation of Flash (thanks Bob) I installed a KLA strut brace. But you know I had to powder coat it before I installed it. I don't like the look of the zinc cromate coating and the quality of the strut bar deserves better IMO. Great quality, but at least paint the support arms first.
Enjoy the photos, The pictures do not do justice to the electric color of the PC. I am having the car aligned next week and will give my impressions of the B&G Springs at some point after I have driven the car for a while. Again thanks Flash, I am using the 3rd alignment specs. you have provided for us. Some track time is in my future but mostly just mountain twisties.
Thanks for everyones input.
Silver BLT
