[quote name='Torbjorn968' post='47785' date='Feb 19 2008, 10:26 PM']Forgot that question: the owner was wondering what Hosiers to get.[/quote]
Hoosier only makes one DOT dry race tire, the R6. If you have a requirement to run a DOT tire like I do, then that's the one you'll run. They also have a fantastic DOT rain tire which you may want to consider if rain is likely. They also make a DOT autocross tire, the A6. Some guys run short sprint races on these, but I wouldn't even consider running an endurance race on these.
They also make full slicks, but I don't have any experience with those.
Also, for the past few years they've been making a spec tire for the Grand Am series in the US. It looks like a DOT tire, and is actually an evolution of one of their previous model DOT tires, but I don't believe it caries a DOT stamp. This tire has been discontinued since Grand Am moved to another tire supplier this year. Hoosier is probably dumping these tires now, so its possible that these are the ones that you're able to source cheaply. I've not run on these, but I have several friends who have. The tire is not as sticky or fast as the R6. However it is more consistent and lasts longer. Grand Am Koni Challenge runs races that are at least 2 hours in length, and the tires are supposed to be designed to go the distance without a change. Some teams may run an entire race on them, but a lot of teams change them about half way through the race since they have to do a long stop anyway for a driver change.
