Porsche PET
The PET disc is now available commercially, but I'm wondering if anyone here knows if it will run under OS X?
I've been looking at the PDF version, which is great, but I've noticed it drops the end of part numbers, and seems to be a different version - if ever so slightly different - than the old PET disc I used to use.
Are you refering to xwindows or gnome? If so, no... I run a Linux box and have to use the pdf version. I also have a laptop with xp which does run PET.
[quote name='S_Cal968' post='28645' date='Dec 1 2006, 04:28 PM']Are you refering to xwindows or gnome? If so, no... I run a Linux box and have to use the pdf version. I also have a laptop with xp which does run PET.[/quote]
thanks s cal... not xwindows but so-called tiger - the unix-based OS that macs now run on intel chips.
The PET program (preceded the PDF) is a Windows app. Presumably it will run under Parallels or BootCamp. It will NOT install or run under OSX.
ahhh.... of course. boot camp. but purchasing/installing/learning windows is I don't think worth the trouble just to run the PET.
PS always good to see that nice engine, etnier.
Last Post by unknown4u
03-29-2008, 12:24 PM
10-22-2007, 06:49 AM
08-31-2007, 03:26 PM
08-14-2007, 07:43 PM
