09-01-2021, 07:00 PM
First and foremost DO NOT TRY this with your car , and certainly a precious 968 ... but as an update to the “ experiment “ I’m conducting with my now 200,000 miles + , 2003 MBZ C-240 to see just how much neglect it can tolerate before it gives up , here’s the latest : I have not changed the oil for the last 100,000 miles ( and it’s conventional oil, not even synthetic ) . The engine purrs like a kitten, and has full power on demand, not a single problem with it . I also have not changed any other fluids in the same last 100, 000 miles ( no coolant / antifreeze , no brake fluid, no power steering fluid, certainly no transmission fluid for the entire 200 K miles, etc. ). Not a problem either . So I’m starting to suspect the “ suggested “ changing fluids intervals is mostly a myth ; yes it does not hurt, but it seems to me it makes no difference either . I will continue to change the ( synthetic ) oil in my 968 and my Maserati probably every 15,000 - 20,000 miles , just because it can’t hurt , but not touching any of the other fluids. As for the MBZ, I’m waiting to see how long it’s going to take until it croaks . Btw, it also has all the original belts and hoses which are now pushing 18 years old and 200 K miles of wear . No signs of cracking .
