Hall Sensor Replacement
The front Hall effect sensor, appears to mount to the back of the cam gear cover. Looking at old posts, some say that it can be replaced without removing the valve cover. I can't see the bottom bolt head, it must be covered by the valve cover, meaning the valve cover has to be removed.
Has anybody documented the procedure for replacing the front Hall sensor?
-sp4149
Haven't had any luck replacing without removing the valve cover.
Not much help, but I removed my Hall Sensor with the cam cover in place.
Try a small mirror and flash light.
Rustec replaced the hall sensor in my car (with me breathing down his throat) and it seemed the the entire top of the engine had to be removed to even get to it. What a MAJOR difference in the way the car performed when he finished.
Ron
94 coupe/6 speed
[quote name='midblu' post='48930' date='Mar 10 2008, 05:09 AM'](with me breathing down his throat)[/quote]
I hope you meant on his neck...
Arash - '95 968 - '93 968
and the best one: '84 944!
Last Post by Roboman
10-05-2021, 01:44 PM
Last Post by pdxmike
06-10-2019, 02:40 PM
12-22-2012, 12:27 PM
