Threads: 10
I did a search on the forum, but the searchfilter didn't fit well.
Can anybody tell me the OEM ride height for a 968cab non M030 in mm from teh wheelarch till center of rim.
Front = ?
Rear = ?
I taught i've red it somewhere ....
thanks
1994 cab : slate gray & bordeaux top + 6 sp. man. + LSD 220 + OEM 17" cup I + stock airbox mod + K&N + RS Barn header + free flow cat + RSB st 2 chip + KW-V3 + M030 sway bars with delrin and KLA + up and lower brace + SS clutch line + rack tack + Stuttgart Shift block
Threads: 10
thanks bob,
14" would give 343 mm (factor x 25,4)
actualy with KW-V3 an my cab i measure 345 at rear and 340 in front, I thaught I lowered the car a bit
is the height in front always the same as in the rear ? when accelerating the rear will copress a bit, so perhaps 5 mm higher at rear isn't too bad
Threads: 7
ok, more questions.
the coupe is 66 lbs heavier rear. is this the 6 speed? how much does the tip add to the rear? since i have been removing weight from the back and may need to
reduce more just to match the 6 speed. damn, I guess I still miss my 6 speed. lol
Also, will raising the rear ride height compensate for the rear weight bias?
Threads: 7
Hi Bob, thanks and my apologies to everyone for hijacking this thread....lim [img]style_emoticons/<#EMO_DIR#>/blink.gif[/img]
Threads: 10
Well, as I have KW-V3, I adapted ride height in front equal as the rear, so 345 mm, but the front feels a bit looser now, and this because of only 5 mm ?
I wrote on the technical form (for legal technical control) that standard ride height = 360 mm, I suppose this is +/- correct.
Threads: 25
All those height adjustments, could the lose feel just be time for an alignment?
Rick
