Obvious to all but me
Ok,
On the driver side, in the trunk, between the carpet liner and the wheel fender there is a motor which rotates a cam wich moves a cable that goes to the rear lock. When I turn the trunk key counterclockwise it activates. The cable bucks up and down as if it is not functioning properly. I looked in the owners manual, on this forum and the only reference is in the dC Automotive schematics
http://dcauto.gotdns.com/illustration/index/518119537
and all it's called is "electric motor".
What is it's purpose?
it opens the hatch (or trunk on a cab)
That seemed to be the obvious answer, I guess it just seemed an extraordinarily over-engineered way to open the trunck latch. I understand the designers had to tie in the electric release button down by the drivers left foot, however to run from the lock around the trunk to a motor mechanism which attaches to a cable which runs back down the same path around the trunk to the latch. wow! I always thought efficiency was a primary German trait!
Thanks again Flash.
If they ever decide to rename this forum they might want to incorporate "Flash" somewhere in the name.
happy to help
I totally agree that it it an absurdly overcomplicated way to pop a trunk lid.
I had to replace a diode in the motor assembly last year.
Tom
??? the motor is serviceable? elaborate please
p.s. - i sent you an email a while back
Yes, please...I'm getting tired of holding this thing since yesterday.
07-14-2009, 04:06 PM
