06-19-2015, 05:19 PM
I'm passing this along because I seem to have rather unusual things happen... The black rubber seal in the throttle body got pinched or something during re-installation. This lead to emergence of anti-freeze into the intake manifold which caused the valves to stick and produced the described noise. I thought "oh damn" its not like I can spray carburetor cleaner through the intake to the individual valves... what to do? The first thing I tried was squirting water into one of the tubes that carries water through the throttle body... thinking that would atomize into the engine, which it did like water injection, but it wasn't quieting the valves at all. Then I go the bright idea to pull the spark plug on each piston while it was running. That did the trick... it "flooded" the cylinder with fuel which broke up the glycol and after several attempts I got all the valves quietly humming along. You can't drive the car with that racket and it would probably burn the valves or ??? I didn't want to have to take the head apart, so anyway, pulling the plugs on each one and a little patience cleared the problem. Really had me going though.
