968 engine no start, injectors firing, no spark pulse
Hi all, a little shoutout to the 968 community, hoping there's someone who could help me on my "no start" issue.
The situation:
I've got a rebuild 968 engine, complete with original wiring loom and ecu sitting in a 944S chassis. After completing the engine swap, the additional switched 12v to terminal 7 on the connector in the passenger's footwel and the wire for the tacho signal hooked up, I tried to fire the engine. It turns over fine, fuel pump is working, injectors firing, but there is no spark pulse coming from the ecu.
Tested so far:
-Crank sensor tested with a oscilloscope, strong and crisp signal with little to no noise
-DME relay
-Wiring loom from ECU to ignition coil
-ECU tested on an other 968, fired up straight away, running smooth
-Switched and constant 12v and ground at ECU connector
Offcourse I understand that there is no way someone can know what's wrong (hooked up incorrectly or defective) by just reading what I've tested and what checked out correctly, but I hope that the distinctive "no spark(no spark pulse at coil), but firing injectors" rings a bell. To my knowledge it's quite uncommen and in the past all my ecu related problems which caused a no spark(and no spark pulse) situation also kept the injectors from firing.
Hope someone could point me in a direction. Wink
nevermind, got it fixed
so what was the fix ?
He lost me at ...wiring loom and ecu...
Problem was difficult to find, but easy to fix...
The additional 12v on terminal 7 I hooked up was one that switched on when turning the contact switch on... But also one that switched off when I started the engine  :whine:  :whine:
So every time I tried to start the car, power to the ecu was switched off, and was switched on again when I stoped cranking. The moment in which the starter stoped and the engine would still turn a bit caused the ecu to read a signal and fire the injectors once...
Now that the ecu is hooked up to a 12v source that is always switched on when the contact switch is on everything is running great Smile
Ok Dennis, next time I've got problems with wires or connectors or any of that stuff you can expect me harassing you quite a bit ;-)
08-17-2017, 09:06 PM
10-05-2016, 04:04 PM
Last Post by williamoss
05-14-2016, 05:17 PM
