[quote name='jfrahm' timestamp='1357938851' post='137316']
It's not guesswork if you use a procedure to test and verify. Something fundmental is clearly not right and it could be that you have not found it due to a wrong assumption, or a test you have not yet performed.
You say your DME relay is bad, how do you know? Are you sure that your jumper is correct and installed correctly?
Is there power to pin 30 at the DME relay socket?
What about pin 86?
I suggest checking for power at pin 7 on the DME connector also with the key on.
I'd really like to see the DME boot up. I wonder if your ignition switch might be bad?
Joel,
OK, here's what I found relative to the DME relay and its socket terminals:
- When I run through the tests of the DME relay described in Clark's garage, it passes them all. So my belief that my DME relays are bad appears to be incorrect
- There is +12V at both pin 30 and 86 at the DME relay sockets
- With the key ion the start position, there is +12V between pins 85 and 86 (suggesting the DME relay should be able to allow power to go to the DME)
- However, there is 0V between pins 85b and 87 with the key in the start position. This appears to explain why I don't hear the fuel pump when I have the DME relay in place, and I turn the key to the start position (the fuel pump does, however, turn on when I place a jumper between pins 87b and 30)
- There is 0V at pin 7 of the DME connector with the key on. Why did you suggest checking this particular pin? According to the manual, it goes to the mass air sensor.
So, I appear to have multiple problems:
1. The fuel pump doesn't turn on when I move the key to the start position, apparently because I don't have +12V at the DME relay socket pin that's needed to energize the coils in the relay to close the switch to activate the fuel pump's circuit.
2. I'm not getting any spark at the spark plugs
3. The CEL doesn't blink when I attempt to perform the blink test
It sure would be nice if I could find something these problems have in common. Tomorrow I'll check to see if I'm getting a signal from the speed/reference sensor (or is it sender?).
