Fuel pump not turning on
I'd all but given up on this forum, because most of the technical, hand-on experts who used to contribute so frequently to the troubleshooting of problems with these cars, which is my main interest, have long since stopped participating.  But with Pete's recent return, there's some renewed hope, so here goes:
It started with a fuel leak coming from where the fuel pump is located, so I replaced the pump, and the copper crush washers, with a new Bosch unit from Paragon, and this cured the leak.  But it has simultaneously developed an intermittent problem with the pump turning on at all.  When I remove the DME relay, and jumper connectors 30, 87b, and 87, it usually energizes the pump, but not every time.  So I removed the cover the pump is attached to, and sent 12V directly from the battery to the pump's connectors, and that works every time.  I checked fuse 34, for the fuel pump sender, but it's fine.  Other things like lights, turn signals, fan, etc., all work.  I tried starting the engine, and of course, it doesn't.  So, either there is an intermittently bad connector or wire somewhere between the battery, the fuse box, the DME, and the pump (which seems unlikely, especially since the car has spent its entire life in the south), or there's a sensor that needs to send a signal to the DME before the DME OK's the delivery of fuel to the engine.  Somebody on another forum suggested replacing the DME coolant temp sensor.  Does that make sense?  It's only about $20, and it's easy to get to, but I hate throwing parts at a problem without establishing the part is the problem.  Thanks.
If you jumper the dme is there 12 volt at the pump the whole time?
If not there is a connector in the wire about 50 cm from the pump. Check that out. Mine has had the discribed symptoms too in the past. It was that bad connector. It looses 2 volt overthere. The connector got hot and opened a bit further. Then the pump quit. The connector cools down and the pump started again... very frustrating.
That was it!  The connector you describe had worked itself loose, probably from taking the fuel pump off and on several times.  Thanks very much - faith in the forum is renewed.
I had exactly the same, dirty contacts in that connection
There you go Cloud, an unexpected Christmas present ;-)
Always have faith in this forum!!
Have a nice Christmas all of you!
Happy to have you back and participating
Last Post by pdxmike
02-08-2019, 11:04 PM
Last Post by Cloud9...68
01-27-2013, 09:03 PM
