Threads: 59
I've been diagnosing my cranking no start for just over day and this is what I have found.
I have a spark at the plugs.
DME works in another Porsche.
Smelled fuel when the spark plug was out and engine was cranking.
Fuel pump running.
Timing belt mark lines up with TDC.
I plan on trying 3 other tests due to idea's I got from various sorces.
Could be a gummed up fuel filter
Could be a gummed up starter
So I have a spare starter that I was planning on swaping so I will try that first.
If that doesn't work I'll try an alarm bypass.
And finally order a new fuel filter for Monday.
Any other ideas?
Rich
'93 968 Coupe Cobalt/Grey Devil with a blue dress on
'96 Ford SHO V8 Silver/Grey Rebuilt Winter '13
Threads: 63
I had a similar problem once, and found that I had forgotten to reconnect the distributor wire to the ignition coil. If you have spark, then it's probably not that, but I just thought I would mention it.
Could there also be a vacuum line leaking or disconnected causing this?
SOLD! 1992 - 968
Threads: 59
Havn't checked the fuel pressure yet.
I just finished installing the starter and no change <img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" />
Going to try the alarm bypass before checking the fuel pressure.
However, wouldn't I notice a change in fuel pressure while driving?
The car had been sitting for 3-4 hours before the no start happened and it was running fine.
Rich
Threads: 59
Thanks Flash and Kwikt.
I will try unplugging and replugging the relay's cuz frankly it couldn't hurt.
I also have 4 DME RELAY's that I can swap out so I will try that too.
Gonna keep my fingers crossed. <img src="/forum/images/smilies/968/unsure.gif" class="smilie" alt="" />
[quote name='kwikt' timestamp='1302997707' post='108513']
Possibly could be the crank positioning sensor in the top rear of the motor. Try plugging and unplugging all your connectors first along with the relays. There is a starter relay in the fuse box. Check it out. Maf, hal sensor, crank sensor,throttle sensor, cold start sensor (If smelling gas it can be this),etc. When running how is the idle??? Idle control valve stuck open?
Where can I find the idle control valve?
Rich
Threads: 59
Update
No go on the relay unplugs
I even cycled 3 DME relays in and out still nothing.
Rich
Threads: 77
Is your tach moving when you crank the engine?
Threads: 42
Are you sure the DME relays that you are trying are the right ones? They are very specific for each car. The old ones are crap, the new ones work much better. Here is the part number
993-615-227-00
Also, clean the contacts for the relay switch in fuse box. use a small flat-tipped screwdriver and some wd-40.
2005 Acura RL
2004 Toyota Sequoia
(This post was last modified: 04-17-2011, 10:14 AM by
rl968.)
Threads: 59
Tach is moving on cranking
I don't know if its a weak or strong spark. All I can tell is that there is one.
Part number for the relay matches
Really starting to think the fuel pump sound I am hearing is a failing fuel pump.
But I am throwing in the towel and having the mech look at it. <img src="/forum/images/smilies/968/sad.gif" class="smilie" alt="" />
Rich
Threads: 13
Do not crank but jumper the DME. Gives a better result because engine is not "shaken" and you can measure the flow.
And do the blinktest as well. maybe an error has occured and stored in the motronic.
Threads: 59
Ding, Ding, Ding!
And the answer is.......
Timing freakn belt!
I didn't notice that the camshaft wasn't moving while we were cranking the engine.
I don't have a clue how I didn't notice that but I just paid $300 to have someone else tell me.
Talk about opid-stay
At any rate, the mech are going to do a leak down to make sure the valves and head are ok but I am confident they are just fine.
This also explains why I was getting spark and fuel.
The camshaft was stuck at TDC so the fuel and spark would work but only for cyclinder #1
Going to order a nice kit from Pelican
http://www.pelicanparts.com/cgi-bin/smar...%20Each%20
Oh, and please no negative comments like "oh, your engine is broke'd" I want to stay positive. <img src="/forum/images/smilies/968/cool.gif" class="smilie" alt="" />
Rich
(This post was last modified: 04-19-2011, 11:40 PM by
Lord_Galva.)
