NGK Iridium
After a search on this site I found the part number, and it is <b>BPR6EIX</b>
However...
My local parts store is telling me it should be <b>BKR6EIX </b>
I have also looked at thre NGK site: http://www.ngksparkplugs.com/part_finder/c...?engineid=38665 and here it states <b>BPR6EIX</b>
Any advice will be appreciated
The one you came up with the BPR is correct. Also the Bosch Iridium is (4506) WGR8DQI
According to this info http://www.ngk-sparkplugs.jp/english/techi...mber_sign_0.pdf
the BK is 2.5 mm shorter in the isolator part. You will probably have a connection problem with the original plugwires.
