Turbo S gear ratios/final drive?
Been searching all over for the gear ratios in the 968 turbo s. Any one have the specs? The goal is to have the transaxle done by summer, for my 93'. I need the exact specs, so I can replicate them. Curious if it used a different input shaft, r&p, etc. I found a parts list once, but it was in German. Anyone have one in English? Or another in German, I can have translated? Even just the part numbers of the differences in the trans would be nice.
i believe it did use a different input shaft, and definitely used different axles
Yeah, got a feeling 1 and 2, used a totally different input shaft. Id give anything for the part number. I know the axles were bigger. These can be had..maybe not OEM tho. I know thicker axles exist..forget where. Thing is Id rather break a axle than R&P. Kinda want it to go first...if its gonna go. Im just hoping I can get the same gearing without needing custom input shaft, and gears. One or the other wouldnt be too bad, but both....the engine build might wait til winter. Im sure it would be very expensive to get it from porsche, but from what I understand, they will one off anything for the right price.
Different 5th and 6th, you can get them aftermarket, try california motorsports.
I was talking to Roger(CMS) on Monday. 5th and 6th are available. No idea if they are the same ratio used in the turbo s tho. He didnt even know, which is why Ive been scouring the net. 1 and 2 will need changed too, which unfortunately is looking like a cu$tom input $haft. If only I knew the exact ratios, and part number for the input shaft, might not be much more to source from factory....if I knew what it was. Wonder if its an audi part. Very little info about this around. Was hoping maybe people, on this site, who own a factory original might be able to shed some light.
try jason burkett at paragon - he has one of the 4 original RS cars
Funny, I just got off the phone with Jason....wheel bearings just got here. Couldnt find wheel bearings on rs barn. I forgot he has an RS. Guess Ill call him back. LOL. I think the RS used different gearing than the S, but he'll probably know.
Ah, missed him. He left for the day. One of the guys in the shop said he has a factory manual....should be a start in the right direction. Thanks Flash, I wouldnt have thought of that.
gears 1 thru 4 are the same as the standard 968 gear set. The only change is the 5th (.882) and 6th gear (.711) and the final drive gear (3.40 vs 3.78)
jpr
taller gears - i LIKE it!!!
i thought about going the other way, and giving up top end to have better acceleration
but that was before the supercharger..................
i still want a shorter final drive.
Here is a chart I found a few years ago.
[Image: a2bb3a5f.jpg]
