steering wheel install
It's certainly true that Radio Shack is no longer what the name represents. However, at least for the location near where I live, I've been surprised at the little pieces they still carry - although only in one small corner area. Mobile phones and other non-Shack-type products certainly dominate. I guess, though, that's in response to the market.
[quote name='SILVY968' post='33305' date='Mar 26 2007, 07:15 PM']You are correct. Must have been beyond my capacity to get that one correct, get it?
Good luck with Radio Shack. They have so few parts now. Times have changed. I had to get mine at a surplus electronics store.
Brian[/quote]
I found 3.3k-ohm Resistors 1/2 watt 5% tolerance. Is this right?
[quote name='badberry68' post='33312' date='Mar 27 2007, 04:46 AM']I found 3.3k-ohm Resistors 1/2 watt 5% tolerance. Is this right?[/quote]
NO NO NO. That value will switch on the airbag warning light.
It says THREE ohm, any wattage any tolerance.
You have THREE THOUSAND THREE HUNDRED Ohms.
The 'k' stands for THOUSAND.
Brian
Digressing slightly - if I want to temporarily disable the passenger airbag and avoid an airbag fault, does anyone know a method to do this with resistors? There are two plugs that connect to the airbag, so presumably each one would need a resistor - 3 ohms each?
[quote name='SILVY968' post='33388' date='Mar 27 2007, 10:40 PM']NO NO NO. That value will switch on the airbag warning light.
Brian[/quote]
<img src="/forum/images/smilies/968/ohmy.gif" class="smilie" alt="" /> ....I did'nt do it yet, pheww! Something was tellng me that the K was wrong, I have to look elsewhere because Rado Shack's resistors start at 10 ohm. Thanks!
[quote name='Anchorman' post='33393' date='Mar 28 2007, 04:42 AM']Digressing slightly - if I want to temporarily disable the passenger airbag and avoid an airbag fault, does anyone know a method to do this with resistors? There are two plugs that connect to the airbag, so presumably each one would need a resistor - 3 ohms each?[/quote]
Yes, That is what I did. EVERY bag gets a 3 Ohm resistor. Do the same thing with these as the driver's plug. See the DIY instructions.
Brian
Thanks. OK, then - let me get my mini-Hammer built, purchase and install a pair of 3 ohm resistors, and - hopefully - airbag light begone!!!
Last Post by ryker
08-25-2013, 10:58 PM
08-21-2013, 09:19 PM
Last Post by DaveN
03-11-2013, 03:33 PM
10-28-2012, 09:12 PM
Last Post by Gotter
03-02-2012, 04:29 PM
Last Post by MC968CS
01-12-2012, 06:29 AM
Last Post by bombfactory
10-25-2011, 02:05 PM
