new oem front springs?
I am replacing the front strut's with OEM's - before I just replace the springs cause I am replacing the struts - are springs normally replaced at certain intervals other than breakage?
no, not if they aren't sagging
Thanks Flash. Now I just need determine if the used 18x10" ET65 rims will fit without spacers.
Use the wheel calculator xls here, it give clearances for tires so it will give you a good idea of fit.
A calculator, Thanks DaveN
Last Post by Kunz
06-09-2017, 05:52 AM
Last Post by mdss
12-28-2011, 04:19 PM
Last Post by mdss
11-25-2011, 09:32 PM
09-15-2011, 01:02 AM
