Poll: would you use the template? - You do not have permission to vote in this poll.
yes
57.14%
4
57.14%
no
42.86%
3
42.86%
Subwoofer Baffle Plate
i put a subwoofer in ryker's car. i made a baffle plate out of 3/4" wood. i trimmed it to fit in the left rear wheel well space of a hardtop. only caulking was necessary to seal it up. it works well, and can handle an 8" driver nicely. i had the foresight to make a template of the shape. if i got it scanned full size, i could put it up here. it may be some effort though to get it done, as i am pretty sure that my scanner is not big enough. i don't want to waste my time.
would anybody actually use it?
And, for a visual. It sounds great and fits perfectly. Thanks Flash!
looks like you're the only one going to have one too.
Would it work on a cab also?
I'd be up for this, Flash. I have a feeling that even my JL sub in the KLA box is not going to cut it. (My car is currently not running due to an electrical meltdown - hopefully will be fixed soon though).
I can do the scanning and piecing together for you, and make a clean pdf file of the template that folks here can download and print out.
[quote name='flash' timestamp='1415564294' post='163556']i put a subwoofer in ryker's car. i made a baffle plate out of 3/4" wood. i trimmed it to fit in the left rear wheel well space of a hardtop. only caulking was necessary to seal it up. it works well, and can handle an 8" driver nicely. i had the foresight to make a template of the shape. if i got it scanned full size, i could put it up here. it may be some effort though to get it done, as i am pretty sure that my scanner is not big enough. i don't want to waste my time.
would anybody actually use it?[/quote]
Flash; I'd like to build one of these for my car; any template or instructions would be great!!
okee dokee.
bomb - let's hook up and get that scanned so we can put up a pdf file. i'll write the DIY when we do the next install in a couple of weeks
Last Post by bva
09-29-2014, 11:23 PM
Last Post by rxter
01-05-2010, 10:57 PM
12-29-2009, 12:51 PM
Last Post by PorscheDude
12-09-2008, 11:02 AM
Last Post by TMturboCAb
07-27-2007, 08:43 PM
12-02-2005, 06:50 PM
