[quote name='KMR968Turbo' post='29467' date='Dec 29 2006, 11:07 AM']AU968: Is it just me or does your VW make the 968 look small? In your picture it really dwarfs it and I always thought the R32 was a small car. *lol*[/quote]
Wideangle lens. The R32 is closer, so the perspective is distorted <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
But anyway, consider these specs:
R32; 968
overall length (mm): 4176; 4,341
overall width (mm): 1735; 1,735
overall height (mm): 1425; 1,275
wheelbase (mm): 2517; 2,400
front track (mm): 1511; 1,478
rear track (mm): 1491; 1,450
curb to curb turning circle (mm): 10,912; 10,759
Weight: curb weight (kg) 1546; 1,400
Power: 177 kW @ 6,250 rpm; 176 kW 6,200 rpm
Torque: 236 ft lb @ 2,800 rpm; 225 ft lb @ 4,100 rpm
So the 968 is longer and lower, and carries a bit less weight for similar power and tq, but the overall package is not so far away in terms of dimensions. I bet most of the extra weight in the R32 is in the 4wd running gear. Specs are from MotorTrend, but the look about right.
Michael
