Threads: 29
The sunroof can be a pretty easy DIY fix - If the motor itself works, I would assume stripped gears. Even if it's the sunroof motor, not hard to swap out - it's easily accessible. There is a very good writeup on
http://www.clarks-garage.com/
AC on the other hand - that could be a somewhat expensive repair depending on what's wrong with it. It could be as simple as needing new refrigerant, or as much as replacing the whole system.
The cracked dash - a used dash without cracks should cost in the 350-450 range, mine took me about 8 hours to swap. Could probably do it in half that now that I know what I'm doing...
If I were you, I would get a <acronym title='pre purchase inspection'>PPI</acronym> on the car by a local Porsche specialist before finalizing the deal. It could reveal worn parts that might end up costing you a lot. Definitely go look at it first to make sure it's something you really want.
Another cab popped up in New York here that could be worth a call:
http://longisland.craigslist.org/cto/3176491259.html
Also, a coupe on the other side of the country:
http://seattle.craigslist.org/sno/cto/3182871700.html
1994 Slate Grey M030 Coupe
Threads: 77
Looks pretty decent, like the color, the paint doesn't look to bad with some good polishing that paint would look really good. Would definitely get a <acronym title='pre purchase inspection'>PPI</acronym> done on it, the plug for the timing belt inspection is missing and it's low on coolant. The interior looks good also, he doesn't have the boot on the top, make sure he has that, or a money negotiating point. I would also have him take money off for the lack of A/C, that seems a little odd that he opted to spend $165 on the A/C delete bracket then going with the very inexpensive weld that he describes. They usually crack if they have been impacted from the bottom, so a good <acronym title='pre purchase inspection'>PPI</acronym> should be done.
Threads: 142
I think one of the most important posts was what Flash wrote: be patient. To get the right 968 will take patience.
I guess the problem may be that you need a car pretty quickly. So my story in the same situation as you? I got a temporary car. It was an '84 944, only 64K miles, perfect condition, about $5K, had it within a week after the 968 was totaled. Yes, the 944 NA is no match for the 968 or a 951, but was still a nice experience. Then I had time to find the right 968, or consider repairing my totaled 968 that I got bought back from the insurance co. Repairing it was the right path, it took some months, but I had a decent but not most desirable car in the meantime. Then after the 968 was all repaired (my deadline was the Ortega Highway run in 2008) I sold the 944 for the same amount. With some maintenance, sales tax, registration costs, the 944 only cost me about $100-$150 per month, which is way less than most cars cost per month. And the end result was the best solution for me. I picked a 944 in very good to excellent condition so I could easily sell it again.
I even still have pics of the 944 here:
https://picasaweb.google.com/syncronicity1/944 It was fun to experience this different car for a while, I let my son drive it as his main car for about 2-3 months after my 968 came to life, was great chance for him to become comfortable with a stick.
So, think about patience and getting a temp car. And maybe you prefer a coupe. You should be able to find a 968 that was not in an accident for the same $ that this one on Long Island has for an asking price. Buying the wrong 968 could cost you way more than the cost of a temp car.
Roland
Roland
Threads: 59
Regardless of what you buy, get a <acronym title='pre purchase inspection'>PPI</acronym> done so that you have a reasonable idea about where the problems may be. I do think the being patient helps. It took me two years to find my 968 and I got the car I wanted at a fair price. With the <acronym title='pre purchase inspection'>PPI</acronym> results in hand I was able to negotiate a lower price than the car was offered at.
I should add, as many others have also stated, these cars are all now pushing 20 years of age or more and so finding a problem free car, or one with no cosmetic issues, or even one that hasn't suffered minor accident damage gets harder as time goes on. Mine got clobbered in the garage where I parked at work resulting in about $5,000 in body and paint work which might be a problem for some when it comes to sell it. But the car runs like a scalded dog and for me that is sufficient.
Chris Vais
2008 Audi A5 Brilliant Black
(This post was last modified: 08-07-2012, 04:21 PM by
Chris Vais.)
Threads: 59
No kidding, the description doesn't match the car in the photos, not to mention the price.
Chris Vais
