More Wheel Size
Considering a set of used BBS RS track wheels. 8J x 17 et 49 Front and 9J x 17 et 52 Rear.
This would appear to move the track of the front wheels farther out than stock. Any idea of effect on handling dynamics of car, to the good or bad with these wheels sizes.
Also wondering if the front track goes wider (and if this has a undesireable effect) if using appropriate spacers on the rear to bring the front and rear track back relative to each other (thought both would be modestly wider) would be a proper remediation.
Any assessment of the BBS RS wheel would be welcome as well.
i had a 52 up front and 47 rear on the MM C2Turbo replicas - no issues
Flash, did you track it with that setup?
[quote name='flash' date='Sep 21 2006, 11:06 AM']i had a 52 up front and 47 rear on the MM C2Turbo replicas - no issues
[right][post="26295"]<{POST_SNAPBACK}>[/post][/right][/quote]
i had it out there once for a few laps - pushed the car pretty hard otherwise though - didn't like the wheels, but the offset didn't cause me any problems, and if anything, helped - i have an even wider track now
Last Post by robadams56
06-18-2016, 09:07 PM
Last Post by parptarf
08-26-2014, 11:47 AM
Last Post by Tahoe968
08-06-2014, 06:45 PM
